Headlight Swap
Old Dec 7, 2011 | 01:10 PM
bocagq45's Avatar
Post Headlight Swap
Puchase the euro 4 buld euro headlights. I removed my sealed oblong shape but wiring doesn't up. Is there a kit? can someone please tell me step by step how to do it? I have the mounts and bezels. No wiring.
Thank you,
Evan
Old Dec 8, 2011 | 08:53 AM
Keith's Avatar
If your talking about going from the Euro single headlight to the quad lights like the earlier American headlights, the wiring is the same, except the lack of the thin red wire which feeds a small bulb that the later cars had. The connectors are different though. When I put 84 XJS quads on my 95 XJS, I cut the connectors off both and added spade connectors. The color coded wires matched up perfectly. I simply taped the end of the small red wire. It'll make the "bulb out" warning light on your dash stay on though. Guess you could put a small bulb on that wire if you like. Hope this helps!
Old Dec 8, 2011 | 08:57 AM
Keith's Avatar
Just re-read your post, if your missing the wiring harness to the new set, you should be able to match the wiring connecting locations by looking at the back of your old light.
hoodun
Nov 20, 2022 02:35 PM
bdboyle
Sep 16, 2019 05:58 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
millertic
Sep 30, 2015 08:11 PM
kevinl
Sep 24, 2015 08:25 PM
