Headlight switch operation
Old Jun 12, 2019 | 06:26 AM
Stang066's Avatar
Default Headlight switch operation
I have a 94 XJS convertible and have just replaced the headlight control module. Now the only way to make the high beams stay on is by holding the turn signal stalk towards me. I thought it used to push away from me to make the high beams come on. This car is new to me and has been broken more than not so I havnt driven it much. Could someone clarify the correct operation of the headlight lever to make the high beams function normally. Thanks in advance.
Old Jun 12, 2019 | 05:44 PM
Welcome to the forums Stang066,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Jun 12, 2019 | 08:25 PM
John1949's Avatar
Default headlight switch operation
Hi , firstly i have to say my xjs is a 77 and may not be the same as your 94 but anyway in my car :- Headlights will be dipped when first turning on your head lights a single pull towards yourself will put it on main beam a second pull towards you will put the lights back onto dipped , hope this helps .
Old Jun 13, 2019 | 02:00 AM
orangeblossom's Avatar
Hi Stang
You do need to have the Headlights Switched on before you can use the Lever for Main or Dipped Beam though not for the Headlamp Flash
Just wondering if you are doing that?
Old Jun 13, 2019 | 04:33 AM
Stang066's Avatar
This XJS is the facelifted version and my headlights are visible all the time. On the stalk there is a switch that I move from left to right to turn on the lights. Then I have to pull the turn signal lever toward me to activate the high beams but when I release it the high beams turn off and just the low beams are on. I thought I used to push the blinker stalk away from me to make the high beams come on and stay on but I can’t remember and now if I try that it feels like I’m going to break something and it doesn’t move away from me.
Old Jun 13, 2019 | 05:53 AM
JigJag's Avatar
I don’t have a facelift car. On my HEs you pull the stalk towards you. I suspect that action was retained regardless of any changes in mechanical or electrical implementation.
Here, on HEs, High beams are held on by a locking relay. This relay mechanically toggles into a new position when powered. Pulling the stalk towards yourself should flip the high beams state; on to off or off to on. If if something continuously holds this stalk switch closed and supplies voltage to the locking relay for too long it can burn out its coil. No more toggle, but you will still get high beams when pulling the stalk. Coil damage is not repairable. The high beam headlight relay in my 80s cars are Hella brand and the size of two regular relays side-by-side in an aluminum case.
SouthernGypsy
Jan 23, 2020 05:59 AM
andys-GR
Jan 15, 2018 04:19 PM
platinummaker
Dec 30, 2017 12:20 PM
86jag
Jul 13, 2016 10:13 AM
'84 XJ6
Sep 25, 2011 07:40 AM
