Heater core gaskets no longer available
Old Mar 24, 2016 | 05:27 PM
jaggedone's Avatar
Default Heater core gaskets no longer available
First a hello to fellow Jag"ers". I just entered the Jag arena with the purchase of a 1989 XJS coupe. Been through the purchase of a classic in need of restoring many times. Had heard that parts acquisition would be more challenging with a Jag and I've come across that "little' inconvenience already.
Steamed windows on the drivers side, tried to explain it away as a little moisture that got in, but that self white lie isnt working out very well. Purchased a replacement core. Have heard that the orings are not the way to go and started looking for the Jag gaskets part # JLM759. They are no longer avail at least in the States.
Now my question is are these just paper type gaskets, sorta like a thermostat gasket in many cars? Or are they rubber? I see no reason why I couldnt cut out a couple of gaskets from sheet stock. Just want to get it right with the right material.
This forum just may become very familiar to me as I make my way down the to do list for the Jag. Hopefully in short time I can contribute back from my hard earned trials and tribulations.
Old Mar 24, 2016 | 06:44 PM
Firstly, welcome to the Forum.
When time permits, please do an intro in the "New Members Area".
I have not replaced a core on the MK3 system, as o/rings usually sorts them.
That gasket looks like it is the seal for the end cover of the heater box. That being the case it would be easily made from whatever is in the workshop, maybe an "Insertion Rubber", or Hi-Density foam. It is only an "air seal" by the look of the parts drawing, and memory.
#4 in the attached parts book copy.
Old Mar 24, 2016 | 07:28 PM
jaggedone's Avatar
Thank you for the reply Grant. In this case that seal is actually for the inlet and outlet for the heated water coming from the engine bay. Here is an image of the heater core. Pictured with it are the orings that come with them but prior experience by many suggests not to use those but use the gaskets instead.
Old Mar 24, 2016 | 09:49 PM
MY BAD, eyes are not what they were. Misread that drawing.
I have only done 2, and used generic o/rings in both cases without any issues.
If the gaskets are what you want to use then any decent gasket material suitable for coolant would be more than sufficient.
A tad more simple on our RHD cars than the LHD sisters.
Old Mar 24, 2016 | 11:24 PM
jaggedone's Avatar
Now I had to think about that for a minute, this assertion that its easier to r&r the heater core if its righty versus a lefty. Is it an Aussie pulling the wool over my eyes, arent each version just a mirror image of the other? or could there be truth to these words?
Well, irregardless I'm falling for the left handed sister.
Thank you Grant for the advice. I think Ill have both the orings and gasket material and once getting her opened up, see what seems best, good to know that orings can do the trick.
Old Mar 25, 2016 | 12:55 AM
warrjon's Avatar
Ive done this and the XJ40 O rings fit, don't know the part number but any Jag parts supplier should be able to help.
According to the ROM the heater core is the same with outlet/inlet on the LHS
Old Mar 25, 2016 | 01:20 AM
Would I do that???????
RHD only has a glovebox in the way.
LHD has a steering column etc etc, and then that wheel crushes your chest when you try and squeeze that bit closer to the workings.
XJ6Paul
Jun 4, 2019 01:23 PM
Old Dude
Jul 19, 2016 09:57 PM
jacktoth
Feb 29, 2016 04:49 AM
worrasf
Feb 28, 2016 07:02 PM
Rick L
Feb 25, 2016 09:15 PM
