Hood alignment
Old Aug 15, 2014 | 11:05 AM
RagJag's Avatar
Bc Xj Yes, I can imagine that too. In fact I took a little grinding tool and rounded the ends of the little bars that are mounted on the bonnet so they will slide out of the latches even if closed. I would still have to remove the hinge bolts but it will be mush easier after that.
Cheers, RagJag
Old Aug 15, 2014 | 11:09 AM
Bc xj's Avatar
Can the latches be swapped for older style?
Old Aug 15, 2014 | 10:53 PM
afterburner1's Avatar
There are three ways to skin this cat or pooch: 1. Buy spring loaded latches. 2. Add a spring, latch to body 3. Drill a small hole in the latch and run a wire to the bottom of the firewall
I like #1, . There are two possibilities of failure of cables. they break or loosen in or come out of the cable stops. Ragjag is right; trying to remove eight bolts from under the car and in there location would be extremely difficult.
(As an aside. does any one know where to buy the cable stops. I brought one to a good size bicycle shop and drew a blank) 0
Old Aug 16, 2014 | 10:43 PM
Old Aug 16, 2014 | 10:47 PM
The above item is from an '86 and is on ebay; if yours looks like this it may fit
I could copy the picture but couldn't add text
MrWhite
19
Jun 14, 2022 07:49 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
jonahjob
Oct 1, 2015 07:54 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
