Ignition control module vs ignition amplifier - same thing?
Old Mar 7, 2017 | 09:50 PM
Jaguar2986's Avatar
Default Ignition control module vs ignition amplifier - same thing?
Hi
I have a 88 xjs that doesn't start and a mechanic suggested replacing the ignition amplifier.
I took a look at rock auto and only see the ignition control module. Are these the same thing? They look similar.
Thanks!
Old Mar 7, 2017 | 10:01 PM
Doug's Avatar
The ignition module (AC Delco # D1906) is *inside* the amplifier...together with a diode and a condenser. 'Tis the module that usually fails; easily replaceable
Old Mar 8, 2017 | 01:32 AM
Daim's Avatar
You can also have a totally different setup, as the Marelli ignition was started somewhere along the 88 line.
Do you have a box mounted to the left side intake manifold?
Old Mar 9, 2017 | 02:47 PM
NJ2003XJ8's Avatar
What are the symptoms? No spark at all? Weak spark?
