Installing Fuel Level Sender
Old Jun 28, 2024 | 04:58 PM
garethashenden's Avatar
Default Installing Fuel Level Sender
I seem to have problems installing the fuel level sender, so I though I'd ask if there's a trick to it? I feels like its hanging up on something slightly, but I can't see what.
The fuel gauge has been bouncy, particularly when the car first starts. Going rapidly between 3/4 and 1/2 full or so. After a little bit it will settle out, a week ago it was about 1/2 full, maybe just under. This past Tuesday I went to drive the car and the gauge read empty, then bounced between empty and 1/8. I was already late, so I took a different car and have only just got around to investigating. I measured some resistances and, from what I can find online, the wiring seems fine. So I removed the level sender and had a look. The fuel level is conveniently right up to the bottom of the level sender opening. It didn't leak, but I wouldn't want it any fuller. Putting the sender in, I need to curve it around an opening in a baffle. That goes fine, but it doesn't want to seat against the tank. There's a little springiness that I think is the problem. I can push it and get the sealing ring on, but I don't think its right. Having just messed with it the gauge now reads empty with the light on, so I've definitely done something wrong. But what?
Old Jun 29, 2024 | 09:52 PM
Jagsandmgs's Avatar
Sounds like it’s upside down.
Old Jul 1, 2024 | 06:48 PM
It seems to be hanging up on one of the baffles. While inserting it I gave it a bit of a twist, and it is now seated properly against the rubber gasket. But the gauge is still bouncing around. This is, as far as I know, the original sending unit for the car, but it might not be. The float is rectangular in cross section, with small radius corners. All the images I see online have oval section floats. When I try to install the sender, the float insists on being horizontal and I think that's why its hanging up on the baffle. So I guess I need a new sender? The float doesn't seem to be available separately. Maybe I need to do that anyway since I'm pretty sure this started after I replaced the fuel tank a couple of years ago.
Asdrewq
Dec 3, 2023 10:16 AM
thom4782
Apr 6, 2019 05:09 AM
agd
Nov 9, 2016 05:09 PM
jagnew
Dec 23, 2015 09:17 PM
remaricle
Dec 2, 2010 05:08 PM
