Jag v12 ign amp
Old Nov 15, 2013 | 04:09 AM
jsc14jean's Avatar
Default Jag v12 ign amp
Hi, all My V12 decided to stop firing. Was told to have the external amp module checked. Sent unit to "expert" here in South Africa. "Expert" duly misplaced/lost my amp. And of course there is nothing/no-one here to help me. Q: are there 2nd hand units available in UK and cost?.
V12 is 1981 model (acc. to VIN no. ) The module (internally) only a cap, some ic? (number GM 1178813) and something that looks like a resitor?
It looks very plain and simple indeed. However without the proper specs, there is of course a problem. Book says that all parts can be simply replaced. If anyone knows which parts to get, its connecting arrangement and output wiring, to the distr. coil etc, perhaps I can do something.,.. Thank you Jean
Old Nov 15, 2013 | 08:19 AM
rgp's Avatar
rgp
the only one in the uk on ebay who will post worldwide I can find is this
whether the wiring connector is correct for your model/type.... you had better check
Jaguar V12 XJ12 XJS Lucas AB14 electronic ingnition amplifier | eBay
Old Nov 15, 2013 | 08:25 AM
Doug's Avatar
The module is AC Delco D1906
I think the cap can be a garden variety generic....not sure.
However, I've yet to find anyone who knows the value/spec for the zener diode.
Even if you got the individual parts you'd still need the casing to properly house everything.
Old Nov 15, 2013 | 09:19 AM
XJRChad's Avatar
Contact Gary at Jagbits. His member name on this forum is Jagbits. He should be able to figure it out for you. He's based here in the U.S., though, not the UK. He does have a supplier that imports all kinds of parts from the UK, plus he has used parts as well.
mbergen
Oct 23, 2019 10:26 PM
Doug
Feb 27, 2019 01:31 AM
Dz1rfj
Jul 17, 2018 10:29 AM
AL NZ
Sep 4, 2015 08:39 PM
d a
Sep 3, 2015 02:34 AM
