Nardi classic horn button - need pix
Old Aug 3, 2019 | 06:38 AM
JigJag's Avatar
Default Nardi classic horn button - need pix
I have a Nardi classic steering wheel whose horn button is missing some component. I’ve googled to see what it is but I’ve not found a single picture of the back of on like mine.
If if anyone has one of these wheels and would pop the horn out and take a pic I’d really appreciate it.
Old Aug 5, 2019 | 10:09 AM
Mike Lore's Avatar
Will these work?
Old Aug 7, 2019 | 06:07 AM
JigJag's Avatar
Thanks Mike, but that’s the newer style button. Mines all metal and, from continued searching in ever wider circles, I believe mine is missing a rubber piece that holds a metal plate over the back hole.
When pressed that flat metal post protrudes out the hole slightly. I’m assuming that the missing plate that the post should contact would have a spade soldered to it for the connector.
Where does this button you have connect electrically? Does the center post just contact the center conductor directly inside the column?
Im just assuming im missing a part due to appearance and not having anywhere to connect the horn spade connector.
ronbros
Feb 4, 2018 03:53 PM
XJsc-guy
Jan 16, 2016 03:14 PM
DpDondero
Jun 26, 2012 04:41 AM
Bostoncamaro
Feb 3, 2012 01:49 PM
j_bond
Mar 30, 2011 11:57 AM
