New Member with New '89 XJS
Old Dec 30, 2008 | 10:58 AM
Doug's Avatar
Default RE: New Member with New '89 XJS
Here's where I'd begin:
On the right fenderwell there should be a bank of relays under a black plastic cover, including the large-ish silver starter relay. Remove the white/red wire and apply 12volts to it. This bypasses the entire control circuit. The starter should turn if its still good, assuming the conenctions at the starter are still intact and clean.
Post back
Old Dec 30, 2008 | 12:38 PM
JagtechOhio's Avatar
There's also a spade connector for that same white/ red wire, adjacent to the transmission dipstick, where you can direct feed the solenoid. I have seen a bad connection at this point cause your problem as well. I'd be testing the starter relay as the most likely culprit.
kevinl
Oct 31, 2019 06:15 PM
carpartsdiscount.com
VENDOR Threads
Sep 9, 2015 07:21 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
