New and need help
Old Feb 6, 2011 | 09:23 PM
Gus's Avatar
Gus
This should get you the electrical information you are looking for. http://www.captainjaguarscathouse.co..._Reference.htm In your case I would be looking for a bad ground for the lights. I had a 93 xj-s and it was a great car. I had installed an Alpine CD changer in the 93 and it worked well I would ask why not an I-Pod. Hope this helps!
Old Feb 8, 2011 | 03:14 PM
xjrguy's Avatar
FF34 on your XJS V12 is a circuit fault for the "A" Bank Injectors. I'd be hunting for a chafed wire in the engine harness, or broken or loose fitting injector connectors on the RH Bank. The ECM has to detect a shorted or open circuit to set that fault.
Happy Hunting!
