No air flow from center vent
Old Aug 27, 2014 | 07:45 PM
RogB's Avatar
Default No air flow from center vent
During a drive a few days ago, had the ac on and noticed that air was coming in only from the vertical side vents, and nothing from the center vent. Turned fan speed to high, didn't matter (by the way, no diff in fan speed between low and medium).
Haven't driven car that much since buying it, so don't know if this problem was always there or not.
Any ideas as to what's causing this?
Old Aug 27, 2014 | 08:27 PM
I blocked my center vent open. It never opened properly since I got the car, some problem with the vacuum I imagine.
You should be able to feel air leaking out from around it though. All that air has to be going somewhere.
Old Aug 27, 2014 | 08:37 PM
RagJag's Avatar
LnRb, how did you block the center vent open??
RagJag
Old Aug 27, 2014 | 10:07 PM
Bc xj's Avatar
On my 86 Coupe I had a vacuum leak in engine bay right behind engine on firewall. It seem the floor, vents and defrost run on a servo type motor. The center vent uses vacuum.
danke
Mar 3, 2016 10:57 AM
explorer364
Sep 14, 2015 07:43 PM
jaaag
Sep 11, 2015 12:53 AM
stype40
Sep 9, 2015 08:14 AM
