Parking brake stuck up!
Old Jun 18, 2014 | 02:36 AM
geoffsxjs's Avatar
Default Parking brake stuck up!
Hey guys,
When I first parked her, she started to roll back towards a tee behind her at a good clip, and I over zealously yanked up on the brake. Now the button won't push in and I can't get it down. Other than not being a MORON next time, any tips?
Old Jun 18, 2014 | 02:52 AM
jimbov8's Avatar
Try pulling up on the handbrake lever a little further and press the button at the same time. It should only take a couple of millimetres to allow the operation of the button.
Hope this helps,
Old Jun 20, 2014 | 01:17 PM
Eskr's Avatar
And if the above suggestion fails, you can always try removing the handle. I found I could remove the hand brake without removing the seat with a small 90 degree wrench/screwdriver, didn't take long. The tension on the wire will be released and you can reset the handbrake, then just put it back.
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
sawduster
Sep 11, 2015 10:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
