Passenger Window Intermittent
Old Aug 21, 2018 | 05:46 PM
89JAGXJS's Avatar
Default Passenger Window Intermittent
Picked up my 89 xjs coupe from shop a couple months ago. On the way home put window down (operated), but would not go up. Removed interior panel to access window. Push window switch - window start/stop/start/stop - then stops going up. I can hear motor "turning", but window channel/gears stops. Only way to get window all the way up is manually lifting/pulling channel/window. Seems like if motor was shot, it would not start lifting at all and make whirring noise when window stops moving up. Any ideas?
Tony
Old Aug 21, 2018 | 08:35 PM
Doug's Avatar
My off-the-cuff guess is that the gears/teeth on the motor, regulator...or both...are damaged
You might be able to see most of the regulator's teeth fairly easily. Probably have to pull the motor to check its teeth.
Tman
Aug 23, 2015 06:56 AM
Valguard
XJ40 ( XJ81 )
Nov 24, 2013 08:36 AM
rboote
Jan 19, 2013 01:09 PM
hunter34
Oct 21, 2011 04:34 PM
dwclapp
Mar 12, 2009 10:37 AM
