Pirelli P600?
Old Jun 17, 2011 | 09:48 AM
clarku's Avatar
Question Pirelli P600?
Any idea when they stopped making the Pirelli P600's in 235/60-15? I've seen on some sites they're selling them, but not sure if I want to buy tires that have been sitting around for a decade....
Old Jun 17, 2011 | 12:09 PM
Doug's Avatar
I didn't know they were out of production...although it wouldn't be a surprise. The demand can't be very great.
There's probably a web page somewhere that explains the different sidewall date codes used by tire manufacturers. With taht info you could ask the vendor to check his stock....and hope for an answer :-)
Old Jun 17, 2011 | 06:44 PM
cadfael_tex's Avatar
Hmm, that is disturbing if they are out of production. Went to Tirerack the other day and they were all that came up for my OE 15 inch wheels. Anything else out there that fits and is a good bet?
Old Jun 17, 2011 | 07:43 PM
Doug's Avatar
The P600 was the last of the 235/60x15s with a "V" or higher speed rating...if that matters to you.
More choices in 225/60x15 or with 16" wheels....which some guys are turning to
Old Jun 18, 2011 | 08:58 AM
Vee's Avatar
Vee
Yes, it's important to note, that if you search for tires based on the car, you'll get a very limited list of options...since they'll all have to be speed rated.
If you do a search based on the size, then you'll get far more options.
I run Bridgestone Pole Position AS980 (or something like that) on mine, and they are fantastic. I've had them on for 10,000 miles now.
Old Jun 19, 2011 | 12:16 PM
clarku's Avatar
Hey Vee, do you have 235/60-15's or did you drop down to 225/60-15's?....I can't seem to find them in 235's.
Old Jun 19, 2011 | 06:56 PM
Vee's Avatar
Vee
I do have them in 225. That's what is standard for my 1996 model.
The only option I have is whether to go 55 or 60. I have stayed at 55.
Old Jun 21, 2011 | 06:08 AM
clarku's Avatar
Default contacted Pirelli and...
They actually still produce P600's in 235/60-15, however....
"Pirelli makes the P600 in size 235/60R15 98W. Unfortunately, the tire is currently on back order and is not available in the US.
Pirelli Tire North America
Consumer
Affairs "
Oh well.....
Old Jun 21, 2011 | 06:35 AM
Had to deal with this sooner than I expected (screw in tire). Ended up with the B F Goodrich T/A at the local NTB.
What difference will 225 versus 235 make?
Old Jun 21, 2011 | 06:58 AM
Doug's Avatar
The circumference is slightly smaller so the speedo will read a bit faster...I'm guessing 3% or so.
Old Jun 21, 2011 | 08:52 AM
clarku's Avatar
Default 2nd reply from Pirelli...
Heard back from Pirelli regarding availability in US
"We don't have an exact time as to when the tire will be available, but it will be a minimum of 90 days.
Consumer Affairs"
Maybe the price will drop once they're available?....
Old Jun 21, 2011 | 09:44 AM
Mine are actually 235's but I saw some folks using the 225's so I was curious. Mine should be here in 2-4 days so I'll give an impression of 'em when I get to drive on them some.
Old Jun 21, 2011 | 10:46 AM
Doug's Avatar
BFG sells the 235/60x15 in their basic "T/A" line up (all BFG tires, as far as I know, carry the "T/A" name...but they're not all the same).
I had a set of the BFG 235/60s (on my XJ6) and they were fine. The regular "T/A" is basically just a tire...nothing really special about them and nothing bad about them, either. You won't have any complaints about them, I suspect.
If you are presently running P600s or other performance tire with a stiff casing you might find the regular "T/A" a bit softer on the corners.
When I had an XJS I ran BFG "Touring T/A" 225/60x15 which was a semi-high performance tire with a "V" speed rating. It was a terrific tire in all respects. I'm pretty sure that model is discontinued now.
I've had 3 or 4 sets of BFG "KDWS" T/As on my XJR and, previously, my Mustang. A very good performance tire, I really was happy with them, but I had to give them up due to low tread life.
I presently have BFG Advantage T/A on my XJR. I am very happy with them...."V" speed rating but it looks like I'll get at least 30k miles out of them which is better than usual as the higher speed rated tires go.
As you can see I like BFG tires :-). I've also been very happy with Michelin and others but dollar for dollar the BFGs always seems to fill the bill for me.
Old Jun 21, 2011 | 04:51 PM
Clive Rothwell's Avatar
Here in the UK, tyres have a shelf life of 5 years, the date can be worked out from a code next to the DOT mark although not all tyre actually have this mark. Altering the width of the tyre affects the aspect ratio ie the height of the tyre and therefore the diameter and therefore the speedo accuracy and the trip computer. I was lucky and paid a fortune for 2 new tyres that were 6 month old stock. Shop around, they are out there - Pirelli UK still manufacture the tyre but "at present, have no plans to manufacture them in the near future." Good luck.
Old Jul 5, 2011 | 10:50 AM
XJ6Paul's Avatar
Consumer Affairs"
For what it's worth, a friend purchased a new set of P600 235/60ZR15 tires just last month at kaufman tire here in Georgia. I think they ship nationwide.
actually tirerack.com has them in stock right now.
Old Sep 26, 2012 | 04:58 PM
Weenie's Avatar
Old post I know but I am looking for a pair of p600's 235/60/13 and been quoted £200 a tyre in jersey. This includes shipping from the uk as they are not stocked here.
Not cheap!
italianjobtony
XJ40 ( XJ81 )
Apr 5, 2016 08:23 PM
Rakka
Nov 2, 2015 09:06 PM
42Ajd
Sep 26, 2015 07:04 PM
AnD3rew
Sep 26, 2015 06:06 PM
Bignige57
Sep 21, 2015 04:45 AM
