Question: What is this completely obsolete engine sensor? :-)
My XJS runs just fine without it.
Picture see attached.
Ok. Lets be serious. What is this broken off sensor?
What does it do (or currently not do)?
And where can I get a new one?
Thanks,
Andy, Clueless Rookie
Thanks,
Car will run fine without it but your pressure may be up a little if there is no vacuum feed to regulator.
that's the fuel Rail temp sensor. from what I have looked at it's the same one that was on mine that I removed because it broke. The wire goes into the same line as the fuel enrichment that's on the throttle capstan "white switch" I just remove that long black thingy and connected the wires together.
what I ended up doing was moving it to the one that Baxter describes which connects to the vacuum line and the fuel pressure regulator. I found one off at X JS that was in the junkyard.
