Replace Engine Front Gasket?
I have replaced all gaskets, rings, and seals I can get to and eliminate any leaks. I have everything off the front of the engine and wonder if I should replace the front gasket. I can see that the gasket has been replaced before with a liquid blue gasket material. I started rebuilding the entire car for the last 3-1/2 years. The oil has been drained for approximately 2 years. I have taken the front bolts off and on a few times removing the water pump and other motors, pumps, and pulleys that were mounted on the front plate. Should I replace the front gasket? Are any parts going to fall out? Are any mechanical adjustments going to be required after removing the cover? If replacing the gasket, who sells a high-quality Gore-Tex-like gasket for the front engine plate?
Toss a coin.
You will need to "unload" the chain tensioner first, so that is a huge caution from me.
Tha gfact its an RTV seal now, someone had been in there, possibly to replace that Boomerang, dunno.
I have been rebuilding this car for over three years. I am very particular with any project I work on. I have cleaned, polished, and clear-coated almost all parts I work on, including nuts and bolts, powder-coated others if the parts are not new. This project keeps going on as I move along rebuilding a part of the car and making the suggested upgrades people have posted. My son and wife said I need to stop digging deeper into resolving potential problems. I work on the car every day I can. I am not going to dig into the front gasket but will replace the chain tensioner plug. Can the Permatex no. 3 sealant liquid be used on paper and other gaskets for a better seal? The can says it is used on aviation Form A gaskets. What is a form A gasket?
XJ6Paul
Jun 4, 2019 01:23 PM
