Seat memory
Old Oct 27, 2017 | 12:20 PM
jordanmc's Avatar
Default Seat memory
Does anyone know if there is a separate unit/module that controls the seat memory buttons. I can hear a relay clicking noise when I push one of the memory buttons but no movement on the seat.
1992 xjs
Old Oct 27, 2017 | 09:26 PM
sidescrollin's Avatar
Yes there is a separate ECU for the driver's seat and the mirrors and another for the passenger's seat. I am not sure of the location.
Page 42/70 in this PDF
http://www.jagrepair.com/images/Elec...electrical.pdf
The first few pages should give you idea of the general location of the ECUs but I am not sure where it means, under the dash or in the transmission tunnel??
I do not have power seats I can't help much here. Try to use that diagram and trace power back until you find the issue. Maybe someone with a newer model can chime in to help you out.
Old Oct 28, 2017 | 05:34 AM
Jagsandmgs's Avatar
The units are literally under your feet. To fit the stuff, Jaguar put a sheet metal hump right in front of the seat and just carpeted it. There are two little metal screws in the front, and it just slides out.
