seat recline angle
Old Jan 29, 2017 | 06:28 PM
BradsCat's Avatar
Default seat recline angle
Does anyone know if there is an easy way to extend the reclining angle of the seats? I'd sure like to be able to lay the seats back at 60 degrees or more. Easier to catch a little sleep on long trips that way.
Old Jan 29, 2017 | 07:10 PM
Vee's Avatar
Vee
Do you want to tell us what model year your car is? (Might be a good time to create a signature so you don't have to remember in the future)
Old Jan 29, 2017 | 07:16 PM
BradsCat's Avatar
'87
How do I create a signature?
Old Jan 29, 2017 | 09:29 PM
Vee's Avatar
Vee
Click on User CP up top in the black bar, all the way to the left.
Then on the left side you'll see an Edit Signature link.
The rest should be easy.
Old Jan 29, 2017 | 09:37 PM
BradsCat's Avatar
thanks
Old Feb 11, 2017 | 03:40 PM
BradsCat's Avatar
Have answered my own question. The answer is yes and it is easy to do. You don't even have to take the seat out if you don't want to.
While removing the headliner from a junkyard car today I took the passenger side seat out to make it easier to maneuver the headliner. With the seat out I removed the side release lever and the cover. You can clearly see a stop post that is welded on the seat frame. It is directly in front of the seat back tensioner spring tip. The seat swivel hits the post to prevent it from reclining any more. By cutting the post off you can recline the passenger seat all the way . I assume the drivers seat is exactly the same.
