Setting Clock
In the '89 Owners Manual, it's near the end of the Instruments Section under "Trip Computer". The minor subject is Time of Day Clock Setting. I had trouble finding it the first time also................and still do. It's not in the index under clock or time.........go figure!
Press the reset button (directly under time button) once, and the hour should flash. Then press the time button to scroll through the hours.
Once the correct hour is showing, press the reset button again. The minutes should then flash. Press time button until correct minutes are showing. Then press reset once more and you should be done.
this is from memory, so hope it's correct.
scatcat
Sep 15, 2015 06:55 AM
Jaguar Forums Editor
Jaguar Press release
Sep 14, 2015 11:18 PM
