Setting Clock
Old Jun 27, 2012 | 06:30 PM
mrtalkradio's Avatar
Default Setting Clock
Silly as the title is, I looked through all 66 pages of the 92xjs.pdf and used the search. How do I set the clock on this 92?
Old Jun 28, 2012 | 12:31 AM
Evo160K's Avatar
In the '89 Owners Manual, it's near the end of the Instruments Section under "Trip Computer". The minor subject is Time of Day Clock Setting. I had trouble finding it the first time also................and still do. It's not in the index under clock or time.........go figure!
Old Jun 28, 2012 | 07:58 AM
Noah's Avatar
Press the time button, so the time (albeit wrong) is displayed.
Press the reset button (directly under time button) once, and the hour should flash. Then press the time button to scroll through the hours.
Once the correct hour is showing, press the reset button again. The minutes should then flash. Press time button until correct minutes are showing. Then press reset once more and you should be done.
this is from memory, so hope it's correct.
Old Jun 28, 2012 | 01:33 PM
Sarc's Avatar
@Noah
I think you're right, although also from memory I think you may need to press AND HOLD the reset button for a few seconds to get the hours to flash ?
Majik Lasers
Aug 2, 2024 01:49 AM
jjlu2
Jan 29, 2016 07:02 PM
simongulliver
Sep 16, 2015 03:40 AM
scatcat
Sep 15, 2015 06:55 AM
Jaguar Forums Editor
Jaguar Press release
Sep 14, 2015 11:18 PM
