Speedometer and odometer issue
Old Feb 27, 2017 | 08:14 PM
Hitch's Avatar
Default Speedometer and odometer issue
I tried to use a Snap-on code reader tool to read codes at my data connection port (OBD2) and it was raining out ( I think this is relevant) There might have been a drop of water on the connector when I plugged it in.
As soon as I went to drive away I noticed my speedometer was not working. Neither is my odometer. Before I tried to plug in the Snap-on tool all was fine. Cruse is also knocked out but that actually makes sense if the speedometer isn't working. All the lights on the dash are good and the rest of the gauges work as they should.
Is there a fuse or link or relay I shorted out?
Thanks in advance for your help guys.
Old Feb 28, 2017 | 11:32 AM
JagCad's Avatar
Hitch:
There might not be a cause/effect on using the Scan.
No cruises is a definite clue. As you say.
I'm not familiar with your car. But, the sender on either the transmission or in some cases, as I recall on the differential. No pulse, no numbers!!!
Add in the moisture comment. Rain. Each location sensitive to road water!!! Ford any deep water???
That is where I would look.
Or, just wait for things to dry out. Some things just fix themselves!!!!
Carl
Old Feb 28, 2017 | 12:29 PM
Hitch's Avatar
Its been 45 days.. not getting any dryer.. haha
Old Feb 28, 2017 | 01:44 PM
JagCad's Avatar
Well, around here over 45 days have gone by. Record rain. Nothing has had time to dry out!!!
But, I'd not rule out sender connection issues. Wet- dry-corrosion?
Or just time to bow out??? The sensors that is.
Carl
Old Feb 28, 2017 | 01:47 PM
JagCad's Avatar
Ooops. Mis read a bit. Still wet!!!!
Down and under with a blow dryer or heat gun on low and dry out the sensors and the connections, wherever they are, trans or diff.
Sunny, but to us a tad chilly out. Fighting with a cold, so I'm on "light duty".
Carl
