tach accuracy/revs
Old Mar 14, 2014 | 01:52 PM
Ezrider's Avatar
Default tach accuracy/revs
my jag has the 4L 6
i think my tach shows high aether that or the shift points re-limiter has been raised and possibly rear end ratio if its correct
in sport mode the tach will go all the way to 7000 rpm before the auto transmission shifts when you put it to the floor. the motor sounds good no valve float or other issues.
anyone have any light to shed on this topic?
Attached Thumbnails tach accuracy/revs-2014-03-13115606_zpsef99d82b.jpg
Old Mar 14, 2014 | 08:52 PM
Bill C's Avatar
Sorry I don't have an answer to your question but, Sammy Hagar comes to mind.
"I can't drive...........55!"
Bill
Old Mar 14, 2014 | 09:03 PM
Doug's Avatar
Doesn't seem right at all.
What happens in normal mode?
Old Mar 14, 2014 | 10:00 PM
Ezrider's Avatar
it won't rev out quite as high in normal mode. speedo is pretty darn close iv compared it to a gps. idle rpm show about 800
Old Mar 15, 2014 | 09:08 AM
barondess's Avatar
Default Tachometer Error
My 1994 4.0 automatic delivers 31 MPH in fourth gear with the converter locked. At 120 MPH the tach should be, all other variables considered, (rolling resistance, wind resistance, etc.) right at 3900 rpm. This is theoretical of course, but an indicator that the relationship between your tach/speedo relationship is suspect.
LnrB
Sep 24, 2015 11:16 AM
jagtoes
Sep 9, 2015 09:56 PM
nosox
Jun 20, 2010 04:52 PM
globalxgear
Apr 18, 2008 07:40 PM
