Throttle issue, help appreciated
Old Apr 21, 2017 | 11:55 PM
Jlackett's Avatar
Default Throttle issue, help appreciated
So recently picked up myself a 1992 Jaguar XJS with the 5.3L V12 engine. The one and only issue that prohibits me from even driving it is that on startup, wether warm or cold, it decides to rev to full throttle and just sit there. I've done a bit of research and not finding much. This most likely is an easy fix, just don't know what it is.
Old Apr 22, 2017 | 12:43 AM
sidescrollin's Avatar
Maybe an iacv issue but it sounds like you just have a big honkin vacuum leak somewhere
Old Apr 22, 2017 | 07:45 AM
Doug's Avatar
Assuming you've checked for a mechanical problem (something physically holding the throttles open) I agree that you have a very big air leak.
Do you say 'full throttle' literally? Like, the engine revs to 6000-7000 rpm?
Are the air filter housings is place? if they are removed, and the bolt holes left open, you'd get a very high idle
Is the 1" diameter balance tube at the rear of the engine in place?
Old Apr 23, 2017 | 04:00 AM
cat_as_trophy's Avatar
. . . and, really basic, check your throttle return springs. Is the accelerator pedal "flat to the floor"?
Cheers,
Ken
