V12 timing (Lucas)
Old Jan 17, 2012 | 11:01 PM
  #41
JameyXJ6's Avatar
Just a quick update. I've chased the wires through the TPS, the CTS and the ATS. I've even switched ECU's and still have the same problem. Starting to get really, really frustrated now...
Old Jan 18, 2012 | 06:58 AM
  #42
Darel's Avatar
Try unplugging the ECU and check for continuity between any of the 3 wires at the plug end of the TPS (unplug TPS too). This will tell you if you have a short in that loom.
Old Jan 18, 2012 | 07:24 PM
  #43
JameyXJ6's Avatar
While testing the voltage to each injector, I found I could simply wiggle the wire harness to the amp, coil and sensors and the engine would die. I picked up several rolls of wire this morning and will be rebuilding the rest of the harness soon.
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
Doug
Feb 27, 2019 01:31 AM
d a
Sep 3, 2015 02:34 AM
XJsc-guy
Sep 2, 2015 11:43 AM
