Vacume hoses rear right intake (V12)
Old Oct 26, 2014 | 05:16 AM
Daim's Avatar
Default Vacume hoses rear right intake (V12)
Hi there!
I'm a stupid person. I took the engine to pieces and took ONE photo of the vacume hoses on the rear right intake manifold... This is now a problem.
I've manage to solve one hose issue... That was the one for the thermo switch or what ever it was again I've got 3 pipes left. One is supposed to have a rubber cap... The other two are now kind of "strange".
One is for the little blue switch, located under the manifold. That is so far understandable and selfexplaining. But I have a rubber 90° hose and can't tell, what else is supposed to join with it.
My V12 is a British spec cat-free Marelli ignition ('89) - incase these differ here...
Cheers!
Regards
Damien
Old Oct 26, 2014 | 06:05 AM
Brake buster's Avatar
there is a vacuum pickup on the top of the right throttle body that uses the 90 degree fitting, and that goes under the TB to a blue solenoid valve
might be that one
IMG_1944 by MyPix on Talk Photography
BB
Old Oct 26, 2014 | 06:15 AM
Other vac hoses there are:
Vac to the transmission.
Vac supply TO the climate system, via the small tank tucked behind the RH bonnet lock.
Vac TO the small Blue/White fuel changeover switch. I THINK Marelli still got that one???????.
Blanking cap.
Old Oct 26, 2014 | 06:16 AM
Daim's Avatar
Hi Brake Buster,
that one is the only one I had a picture of... But no... There are 4 pick ups. One of them is sealed with a cap. One for the blue switch/valve under the intake. Another for the upper switch (see your picture, the beigey thing on cylinder 6A). and the last one I can't seem to determin. That has a 90° pick up ON the vacumm plug...
Old Oct 26, 2014 | 06:17 AM
Daim's Avatar
Blanking cap.
Vacume to transmission! THAT is the one! AH! Cheers Grant!
Old Oct 26, 2014 | 07:14 AM
Daim's Avatar
Just plugged it in again... All holes sealed now!
Not much missing in order to be complete again
dsnyder586
Dec 29, 2024 07:39 PM
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
d a
Sep 3, 2015 02:34 AM
