Wire ID
Old Jul 12, 2014 | 06:35 AM
freejag's Avatar
Default Wire ID
I had to pull the main tank, so I was cleaning grounds by the battery. I have a red wire connector, 4 hole, by the battery that is not hooked up. It actually has both male and female connectors, but the one side looks closed off. Does anyone know what accessory it may have been for?
Old Jul 13, 2014 | 03:14 PM
sidescrollin's Avatar
that is definitely the hookup for a trailer. I found mine when i pulled the tank too. It was stuffed away behind the panel where the ECU is located. It was good for a giggle while having to wrestle the tank out
Old Jul 13, 2014 | 05:30 PM
freejag's Avatar
I cant imagine someone putting a hitch and towing a trailer with a jag. Maybe for the Harley?? Thanks for the answer. I was hoping it may have something to do with the rear fog lights that I could tap to get the front ones to work
Poet
Feb 7, 2025 02:18 PM
jagent
Jun 5, 2022 02:18 PM
Rocky15
Sep 28, 2015 04:59 PM
FabCat
Sep 26, 2015 12:16 PM
driver safz
Sep 26, 2015 06:01 AM
