wiring issue.. many.. seventh
Old Apr 22, 2023 | 12:39 PM
rckunze5's Avatar
Default wiring issue.. many.. seventh
Sorry for so many posts...
This is the mass of wires, on back right of engine. Most of the terminal ends- I don't recognize... I don't have wires with post connectors to go to them...
Old Apr 26, 2023 | 12:42 AM
FerrariGuy's Avatar
Well the white spade connector is probably coil + to the main or 2ndary coil (will be hot with key-on). The White/Blue wire is likely the tacho connection from the amp as seen in reply #3 to your other post: https://www.jaguarforums.com/forum/x...0/#post2635465
The white bullet connector might be +12V ignition to the AB14 Lucas amp.
Not sure on the brown bullet connector. Are there more colors on that wire like brown/black? (right location for the oil pressure switch which is BN) Usually "N" or "brown" is battery +12V.
~Paul K.
Old May 1, 2023 | 06:56 PM
rckunze5's Avatar
Thank you.... I have realized I did not do a very good job posting these... will use your info- and see how far I get. I may try to 'redo' the posts with better photos and more info. Thank you again
rckunze5
May 2, 2023 12:30 AM
rckunze5
May 1, 2023 07:07 PM
rckunze5
Apr 22, 2023 12:28 PM
panthera999
Feb 14, 2023 10:06 AM
LT1 jaguar
Oct 28, 2019 10:58 AM
