wiring issue.. many.. sixth
Old Apr 22, 2023 | 12:36 PM
rckunze5's Avatar
Default wiring issue.. many.. sixth
Ok... this wire is zip-tied to end on left front of engine... has heat wrap on it... no idea where it goes either....
Old Apr 26, 2023 | 12:32 AM
FerrariGuy's Avatar
Well, there's not much w/ that color combination, and not in that area except if it were a RHD car (or part of an RHD car harness was still in use in 82... which is a possiblity) as those are the right colors and placment for a RHD brake level sensor:
The location is also right for the washer pump connection on an LHD car, but the wrong colors.
Paul K.
Old May 1, 2023 | 07:07 PM
rckunze5's Avatar
Thank you- It has the heavier heat wrap- that wires laid on top of the engine had.... I will see if it reaches to the brake- because its zip-tied up.... I just have a feeling the previous owner tied them up - but no info as to where they may go. Thanks again!!
rckunze5
Apr 25, 2023 11:51 PM
rckunze5
Apr 22, 2023 12:35 PM
rckunze5
Apr 22, 2023 12:28 PM
bullittandy
Feb 21, 2023 12:12 PM
mrfixit99
General Tech Help
Jun 22, 2018 04:11 AM
