XJS 5 speed swap
Old Feb 11, 2013 | 02:09 PM
Pif's Avatar
Pif
Originally Posted by calvindoesntknow
Google jaguar v12 bellhousing and it comes up. It fits both bw and th400 block patterns they also sell a flywheel I believe
I think V12 Jaguar Bell Housing is what you meant?
Looking around at specs, it looks like even the WC versions are only rated to 300 ft/lbs, that doesn't leave much wiggle room does it?
Old Feb 11, 2013 | 02:34 PM
calvindoesntknow's Avatar
They sell high strength gearsets for the t5. But I also know people with stock economy t5s behind 460bbf with no problem
Old Feb 11, 2013 | 03:28 PM
JameyXJ6's Avatar
That's the bell housing supplier I've been looking at.
I'm told you need to stay away from the T5 trannys that came in the Chevy S10's. They have a smaller input shaft that isn't strong enough for the torque of the V12.
Old Feb 11, 2013 | 03:54 PM
unfortunatly the only case that will fit right is the mustang case. so IMO buy a ford t5 core and rebuild with gm gears. It can be done, and they are not hard to rebuild
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Greg Reed
Sep 11, 2015 08:41 PM
wardo5757
Sep 11, 2015 11:31 AM
