XJS 6.0 V12 Starting problems
Having problems with my 1994 6.0 V12 and was wondering if anyone could help.
I bought the car abroad and had it shipped over. It was all running before. When i got the car, it wouldn't start. I tired jumping it but the engine turns over and doesn't fire up.
I put a new battery on it and it turned over on its own but still didnt fire up. I then checked all the fuses and the ecu fuse 15a was blown. So put a new one in and it started fine.
When it started up - the battery warning light was on all the time. On testdrive of about half a mile it misfired and switched off and water starting leaking out the bottom of the car.
Upon further inspection, the coolant expansion tank was leaking, which i have changed. Also i had to recharge the battery as it seems like the alternator is not charging it. Still cannot get it to start.
I have changed spark and fuel but still no luck. If i crank it for a long time it does want fire up but it it does - its only for a few seconds.
I can smell fuel and can hear the fuel pump priming.
Another thing i was thinking was someone may of jumped it and spiked something and that could of blown the alternator - im just thinking of the worst.
Any help would be appreciated
Im based in Milton Keynes
