xjs conv trunk stuck
Old Jul 29, 2010 | 03:13 PM
Fraser Mitchell's Avatar
Hi Palmert
Others will no doubt know the exact process, but it wont need a cutting torch,that's for sure !. You may, however, have to drill a hole in the boot lid behind the number plate. This gives access to the lock mechanism.
There may be other, non-intrusive methods, but that is the one I heard about.
Old Jul 30, 2010 | 06:47 AM
deepee's Avatar
When no other means (tricks with key, electrical wiring, ... ) can help you, here is a way to break in your car trunk with brute force:
you can open the boot with long nose pliers quite easily. a hole of 1'' in diameter is required located directly under the boot lock at about 4.5'' from bottom edge of the trunk bootlid.
a blank grommet seals the hole and is then covered by the numberplate.
hope you need this procedure as backup plan only.
Old Oct 22, 2010 | 11:45 AM
xjs40l's Avatar
I was locked out of my trunk caused by a bad lock assembly motor and a bad lock barrel.
One uni-bit and 10 minutes and the trunk was open.
Photo 1
Hole drilled
Photo 2
Close-up. You can see the hole in the latch piece. Insert a cross-tip screw driver and push down.
Photo 3
Lock assembly with the lock barrel removed. This is the little motor that moves the plastic piece to the left or to the right when you lock/unlock the car with the alarm. The motor is bad and I have to source a replacement.
Photo 4
Close-up of motor
Photo 5
Close-up of latch assembly. When drilling the hole ensure you do not drill through the micro-switch. This is the trunk light microswitch. In addition to the trunk light, the alarm system keys off of this switch. As you can see in the photo, I nearly ruined mine!
Attached Thumbnails xjs conv trunk stuck-img00139-20101021-0900.jpg   xjs conv trunk stuck-img00140-20101021-0900.jpg   xjs conv trunk stuck-img00141-20101021-0936.jpg   xjs conv trunk stuck-img00142-20101021-0958.jpg   xjs conv trunk stuck-img00145-20101021-1020.jpg
Old Apr 16, 2017 | 08:56 PM
richardgreever's Avatar
Thank you. you just saved my bacon. Remove the tag bore hole and SUCESS. The rod had come loose. Got a rubber plug to fill the hole and put the tag back on.
Old Apr 17, 2017 | 03:35 PM
JayCee's Avatar
On my 94, I took a long skinny screwdriver and went in thru the license plate hole and pushed the lever. No drilling required.
...Jimmy
BadKat174
May 26, 2023 12:29 AM
Rivguy
Dec 4, 2020 07:55 AM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
UalCapt
Sep 14, 2015 01:42 AM
