Xjs coolant change
Old Sep 28, 2017 | 01:19 AM
afterburner1's Avatar
Default Xjs coolant change
Hate to pose this question, it is so rudimentary.
To drain a '93 6 cyl there is no petcock on the radiator must pull radiator hose. There is an engine drain plug that I suppose you drain first for better fluid control. Which side is the plug on and general location, please?
Draining a radiator was never a big deal, but with environmental rules things become more difficult
Old Sep 30, 2017 | 05:52 PM
sidescrollin's Avatar
Frequency overrules thoroughness, as with reservoir only brake fluid changes.
Idk if the plug is pipe thread or not, maybe you need Teflon tape or maybe it uses a crush washer. Either way, here it is according to my Jag manuals.
Picture is for a 3.6. Not sure if this plug exists for all iterations.
Old Oct 1, 2017 | 11:27 AM
Side, Please excuse the informality of calling you by your first name.
Picture was great and the write up helped.
On my model I have no petcock and have a cat converter! Jaguar got me again!
Old Oct 1, 2017 | 11:50 AM
Those tricksters! Does that drain plug still look to be there at all?
Loads of cars don't really allow for this anyway. Like I said, doing it only partially will suffice with some items like this. Just pulling your lower radiator hose will get plenty enough out. Run some water through to flush it a bit more thoroughly if you wish.
Maybe its worth considering switching to waterless coolant in the future?
