XJS headlights
Like I said... they come in different temperatures. I likes it cold, and pure white, on my white car. No mimicking. In your case, order a set of the temp you want and go driving. Simple.
After much consideration, I ordered a set of LED headlights and reverse lights from Gil Keane at Better Car Lighting in the UK. All my questions were answered promptly and professionally, with a good dose of humor thrown in as well.
Currently running Sylvania 9004 SilverStar Ultra Halogens, as reviews indicated they were the best/brightest I could get in halogens (that were available locally). I've driven with these at night only a few times, and they are quite good. However, my local roads are almost uniformly well lit. Want the LEDs because I sometimes travel at night to somewhat more remote areas with little to no road lighting.
More as it happens.
More as it happens.
I'm still learning about LEDs but that explains why they seem to be more prone to failure (at least seem to be more finicky). Or maybe I just get unlucky with a bad egg every once in a while. The thing is these bulbs are made all over (mostly China I bet) and quality control is questionable. I've tried all brands. I'm speaking of floodlights here (household) and ceiling can lights of which I have at least 50 inside and another 20 or more outside. As for automotive LED lights I do not have any experience with them - but perhaps my wife's 2015 ML350 has them? Haven't had it long enough to know yet.
We were running some expensive Incandescent halogen headlight bulbs in my wife's '92 XJS coupe as well., but with the Euro Style headlights - not impressed (and the lenses are still clear). We finally spent the money for a set of the better rated (HR) LED headlight bulbs. A fairly simple install, and WOW - completely blew the Halogens away - not quite as good as the OEM LED headlights in my 650i GC, but in the ball park. We consider them worth the money and warranty included..
Hmmm the '95 didn't have sealed beam quad headlight, it has the one piece Euro headlight. I believe some came with glass fronts and later ones with plastic fronts. Both kinds take H4 bulbs accessible from a removable panel in the wheel arch / fender .
The main problem with US sealed beams is that they not only don't dip to the side they also have a much lower wattage than H4 bulbs.
My '92 MY with wires, quad headlights and a small leaper, which uses the same holes as the growler so l can change out at will..:-)
mickjaguar
Dec 10, 2014 06:27 AM
