'07 NA Denso AC recharge data
Old Apr 9, 2026 | 08:17 AM
panthera999's Avatar
Default '07 NA Denso AC recharge data
Just got a the car's first AC recharge since new (18 years...). Data may be helpful:
'07 NA base, uses Denso AC system. Recharged using standard R134 recharge system.
Pre-recharge system pressure from HVAC controller: ~130 psi.
Post recharge pressure from HVAC via OBD: Avg around 170psi, ranging up to >200 psi (when braking)
Post recharge Evaporator temp: 42 deg F
R134A Recharge amounts: 230 grams in system, recharge up to 700 grams.
Point is you can check your AC condition with a OBD reader. I used the Autel AP200 with JLR download, live data from HVAC controller.
BTW, my info is never use the recharge cans. Correctly done system vacuum/recharge is about $100-120 or so.
A note: this is a very typical AC system -- nothing unusual about it. Only thing specifically "Jag" might be the programming in the system controller. Any competent garage with a machine should be able to do it.
Hope this helps.
Old Apr 11, 2026 | 11:18 AM
Clarification:
Note that system pressure varies by demands on system.
If it's 70F (21C) outside, and you want 70F inside, it may display 125-140 psi at the HVAC controller data readout.
If you're at 85-90F (26-32C) outside and you want 70F inside, it might operate at 170-200+ psi.
Point being, if you see 130 psi at 80F, you may need a recharge.
Kay094809
Aug 14, 2024 08:58 AM
indyx358
Jul 24, 2021 12:52 PM
Mprimo
Sep 19, 2020 11:14 AM
44lawrence
Jul 27, 2015 05:38 PM
e1rfw01
May 10, 2014 09:03 AM
