07 XK Chrome Side Vents
Old Mar 16, 2012 | 06:04 PM
Thebeachatnight's Avatar
Still learning - figured out how to add before and after pix at dealership when they put the new louvers on. I'm really pleased!
Attached Thumbnails 07 XK Chrome Side Vents-img_3572.jpg   07 XK Chrome Side Vents-img_3574.jpg
Old Mar 16, 2012 | 06:35 PM
Originally Posted by Gn4hir
Ok, call me a cheap skate but $2600 for the vents seems pricey. Ok, I actually think it is crazy.
I'm going to make a two suggestions and don't dismiss them offhand because both are viable. First, have your existing vents covered in alum appearance vinyl. First, it is cheap and second, if you don't like the look you can remove it. Just look for local shops that do vehicle vinyl wraps.
Second and a much better option, have the existing vents water transfer dipped with an aluminum finish. This is very durable and by comparison cheap. If you don't know, water transfer is the process of covering an item with a vinyl graphic layer dissolved in water and then clear coating it. You can even purchase do it yourself kits for $100, although since you might spend $2600, spending a few hundred to have it done professionally seems logical. Here is one random shop I googled Water-Transfer Hydro-Dipping Printing Services
I have shotgun stocks done in this fashion and they are extremely durable and the final clear coat can be done in gloss or matte depending on your desire.
Anyway.. my .02
On the tail pipes (?) - mine are already chrome, was your suggestion specifically if they were not or is there a reason to do that?
02jagstype
23
Oct 23, 2022 07:03 PM
danke
Mar 3, 2016 10:57 AM
doctordeuce
Sep 12, 2015 08:30 AM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
