'07 XKR conv - wiper not spraying on passenger side...
Old Sep 28, 2013 | 01:32 PM
MsBee's Avatar
Default '07 XKR conv - wiper not spraying on passenger side...
My passenger wiper no longer sprays. I suspect there is a hose disconnected somewhere and in fact, there is a downspout-type thing in front of the passenger wiper joint that looks like it should have tubing attached (similar to the driver side) but I can't find any diagram showing the tubing layout. Can anyone help? I don't think there is a clog, but I'll try that if anyone can offer assistance. Anyone know if the tube that connects to the passenger side is visible just like the driver side (once the hood is lifted)?
Old Sep 28, 2013 | 01:41 PM
MsBee's Avatar
Below is the downspout I referred to in my original post. What is this?
Attached Thumbnails '07 XKR conv - wiper not spraying on passenger side...-photo-skitch-document.png
Old Sep 29, 2013 | 10:20 AM
JeremyB's Avatar
I suspect the tube you show in the photo is a drain tube for the wiper box ??
I've attached a couple of diagrams from the XK (X150) Workshop manual that might help, but it doesn't address your problem specifically.
I'd suggest disconnecting the passenger-side tube and blowing thru it ??
File Type: bmp
File Type: bmp
Old Sep 29, 2013 | 12:59 PM
MsBee's Avatar
Thank you for the diagrams. Worked on the car yesterday and found the problem was a disconnected tube. The spout in the photo I posted is not a spout at all but rather a mounting screw to hold the plastics down. We were able to pry up the plastic at the base of the windshield just enough to fish out the tubing with needle-nose pliers and reattach. Works like a charm again!
johndahlheimer
Sep 17, 2020 03:10 PM
kevinl
Oct 31, 2019 06:15 PM
CaneCounsel007
Nov 13, 2015 09:05 PM
UalCapt
Sep 14, 2015 01:42 AM
XJsc-guy
Sep 2, 2015 11:43 AM
