2007 XKR touch screen stays blank. Works occasionally for a short while
Old Nov 3, 2023 | 12:48 PM
crabsonman's Avatar
Default 2007 XKR touch screen stays blank. Works occasionally for a short while
The touch screen stays black. Tries to reboot sometimes the jag logo appears and then the infotainment appears Everything works including radio only to go blank again. I’ve pressed the radio knb and start buttons for 20 seconds
Has anyone else had this problem?
Old Nov 3, 2023 | 01:36 PM
CA Jag's Avatar
Check the battery voltage. Standard first step w/ any electrical issues. How many miles? Have the same car. Haven't had this problem. Only challenge is not getting traffic tickets. Good luck
Old Nov 3, 2023 | 01:56 PM
crabsonman's Avatar
Hi
the battery is all good. Replaced this summer
Old Nov 3, 2023 | 02:07 PM
CA Jag's Avatar
Still need to check actual voltage. If you don't have a trickle charger, these cars drain the battery. Problem may be something else but this is the standard first step.
Old Nov 3, 2023 | 04:34 PM
sov211's Avatar
Originally Posted by crabsonman
Hi
In itself, this means nothing. Unless you charged the new battery before installing it, and if your use of the car involves mostly short runs, the battery may never have reached full charge. And note that new batteries are almost NEVER fully charged at purchase. The first suspect for ANY electronic issue is the battery.
Old Nov 3, 2023 | 05:08 PM
Cee Jay's Avatar
If your battery turns out to be good, these displays sometimes do go bad. With some modifications, a screen from an XF will also fit and work and are much more plentiful. There are a few threads in here already to help, use the SEARCH function or Google with "jaguarforums" also in the search block.
panthera999
Dec 30, 2021 11:37 AM
silversurfer1221
Oct 1, 2021 02:05 AM
Adam Lueb
Jul 5, 2014 01:08 PM
loulizjag
Mar 16, 2012 06:06 PM
