2008 XKR Headlight Malfunction
Old Mar 13, 2017 | 03:07 PM
olkarz1's Avatar
Default 2008 XKR Headlight Malfunction
Good Day everyone.
Both headlight were working last night, but now only the driver's side headlight comes on.
Parking light, turn signal lights all work, no problem
check the fuses and they are good, but the passenger side light won't come on, even if I flash the lights or turn on the high beams
I had an accident with the car and it was hit on the passenger side, but the complete headlight assembly has been replaced
Any insight or experience in resolving this issue would be greatly appreciated.
Old Mar 13, 2017 | 04:00 PM
sov211's Avatar
This sounds like a loose connection - which you can check yourself. Instructions for removal of the headlamp assembly are in your owner''s manual ; it is very simple.
Old Mar 13, 2017 | 04:39 PM
Stuart S's Avatar
Many insurance companies provide a "lifetime" repair guarantee if you use one of their recommended repair shops. If your car was repaired with this guarantee, I would take it back to the repair shop and let them sort it out.
Old Mar 13, 2017 | 09:46 PM
jokerswild1's Avatar
There is a gound mounted under headlight. Check it and connection plugs. Good luck
