3rd Party harnesses needed for Nav project
Old 11-24-2020, 10:00 AM
slash32487's Avatar
Default 3rd Party harnesses needed for Nav project
does anyone know what 3rd party harnesses match the x150?
i know the volvo one matches the Integrated Audio Module with a different pin out. the other 2 im missing are the information and entertainment control module green 16 pin and the one fore the touchscreen that only has the red and the black wires connected to it which also looks like a 16 pin harness.
IECM
IECM
IAM
Touchscreen
Whole Head Unit
Old 11-24-2020, 11:38 AM
Bill Mack's Avatar
More information may help in getting an answer to your question.
If possible, please provide:
  • Year of your XK
  • Base or upgraded sound system
  • Part numbers if any for the components shown and the harnesses you are trying to replace
  • Whether you are planning to install the separate components shown into the apparently complete head unit shown
  • Source of the components shown with cut harnesses.
Others may suggest more. Thanks.
Old 11-24-2020, 11:46 AM
slash32487's Avatar
mine is a 2012 jaguar xkr convertible with bowers and wilkins which i believe is the upgraded system.
the headunit above with the plugs in is my actual head unit
i believe the part numbers as per the electrical guide is IP087, IP061, IP063
Im working on replacing the stock head unit with a 3rd party one. its a project and i dont know if it will work but i do not want to touch any of the stock wires so im looking for 3rd party harnesses so i can use those wires.
attached is a working project.
The following 2 users liked this post by slash32487:
Bill Mack (11-24-2020), Cee Jay (11-24-2020)
Old 11-24-2020, 11:49 AM
Cee Jay's Avatar
Received 5,254 Likes on 3,130 Posts
I'd think a 3rd party harness will have to be one you make yourself. There may be a market for it once successful completion of your project.
Old 11-24-2020, 01:56 PM
Bill Mack's Avatar
slash, that's a good diagram but it leaves open some questions.
  • Do you have the connector that mates with the male 16-pin connector on the touchscreen that you show in the next to last picture in your original post?
  • Have you traced the wires you will need to run to the terminating connectors?
  • Do you have replacement connectors for the ones at the termination of these wires? (You said you did not want to alter the current wiring)
Old 11-24-2020, 02:17 PM
slash32487's Avatar
currently i only have the intergrated audio Module Harness. this is the same harness people use for the AUX hack. i do not have any of the other harnesses. im considering buying a full OEM harness and IECM and creating my own harness. i do not have any plans for the Display Screen harness. i am trying to see if Metra has something that fits.
the wires are layed out pretty clear in the electrical guide. so ive traced what i believe to be the right wires that should go to the pioneer harness. i will be testing them before connecting them.
for your last question i will be using a male to female harness retaining any unused. concept below
There are other open questions which i havent addressed in my original diagram
Old 11-24-2020, 03:53 PM
Bill Mack's Avatar
It sounds like you have done a lot of research. I don't think I can advance the solution further than where you've got. Good luck with it and let us know how it turns out.
curlycat
10-23-2020 12:19 PM
rayclark1
12-08-2018 05:18 AM
ManoFlem
02-24-2015 08:08 AM
mjtemple
04-01-2013 02:36 PM
Quick Reply: 3rd Party harnesses needed for Nav project
