Alignment question
Old Jun 25, 2020 | 07:34 PM
JaguarXKR's Avatar
Default Alignment question
Hi All,
I had new tires put on my 2008 XKR coupe yesterday. I also had them do a 4 wheel alignment. I was told they can't adjust my rear camber. Is this true?
Old Jun 25, 2020 | 07:49 PM
Reverend Sam's Avatar
I will say upfront that I don't actually know the answer to your question. However, most modern cars are like that. The camber is a function of the weight on the rear axle and the strength of the springs. That's why you see so many "souped up" Hondas with the rear tires all ****-eyed. As the rear end gets lower the tires roll on the inside edges. There's no way to correct for that.
Fortunately, camber only has a minor affect on tire wear. You're only 0.1 degrees out of the specified range. That 0.1 degrees is negligible. A few pounds of weight in the trunk could cause it to be 0.1 degrees off.
Old Jun 25, 2020 | 09:21 PM
jahummer's Avatar
There is no specific camber adjustment in the rear however other tweaks in the alignment can have an impact on rear camber, as well as ride height, but as noted, yours is of no concern for tear wear.
mshedden
Apr 11, 2018 01:57 PM
lc3566
Apr 8, 2016 08:33 AM
jagtoes
Oct 22, 2014 07:02 PM
bfsgross
Oct 4, 2011 08:57 AM
jagxkrtoofast
Mar 7, 2010 04:03 PM
