Any thoughts on what this unit is under the rear valance?
Old Feb 28, 2026 | 10:32 AM
AndrewD's Avatar
Default Any thoughts on what this unit is under the rear valance?
Hi guys, I just noticed a single wire under the spare wheel coming from the harness by the battery and leading to a small black box attached to the rear valance. Does not appear to be OEM as the wire is not sleeved. I have no idea what it is. The unit is 6 inch by 3/4 inch by 1/1/2 inch deep with no markings on it.
Also should there be a trim panel attached to the underside of the valance as the valance has several holes with clips along its fwd edge?
Old Feb 28, 2026 | 12:03 PM
LJRXKR's Avatar
It looks like a fog light to me. Can you check and see if it turns on with your lights?
Old Feb 28, 2026 | 01:15 PM
AndrewD's Avatar
Checked with main lights, spots and fog light, brake lights on/off, no change.
Old Feb 28, 2026 | 02:13 PM
kj07xk's Avatar
Guess you have to take it off to see. Might be label or markings on the other side. Once it’s off, you can disassemble it to see if there are lights inside. Maybe it’s an infrared receiver for some purpose.
Old Feb 28, 2026 | 02:58 PM
Cee Jay's Avatar
It looks sort of like an infrared sensor to me, like an aftermarket sensor for reversing.
My rear valance differs from yours, it extends further curled towards the front and has mounting points that connect to the areas where your clips are located. I'll try to take a photo.
Old Feb 28, 2026 | 03:31 PM
AndrewD's Avatar
Appreciate the responses.
I'll wait a while longer then I'll pull the unit for possible hints and try and follow the wire.
Jssaab
XF (X260)
Mar 29, 2025 06:59 PM
JJS- Florida
Jan 18, 2024 09:51 AM
scottatl
Oct 15, 2022 11:28 AM
POD XF
Feb 21, 2022 12:58 AM
Brake buster
Mar 4, 2008 06:34 PM
