chirping sound while idling
Old Dec 5, 2014 | 10:53 PM
captusnr's Avatar
Default chirping sound while idling
Just had new fuel rail and thermostat installed at the dealer. Now I'm hearing chirping sound from engine bay while ideling. Can't hear it from interior only while outside of car. I'm taking it back tomorrow. Any thoughts on what may be causing it?
Old Dec 6, 2014 | 07:06 AM
gatekeeper's Avatar
Just a guess. Might have gotten some fluid on the drive belt when changing the thermostat. Try a finger full of silicon paste on the drive belt, not a lot just in one spot. The running engine will disperse it. Don't apply paste with the engine running. Shut the Jag off then apply the paste.
Old Dec 6, 2014 | 09:12 AM
Mikey's Avatar
Even easier, just squirt some water on the belt. If the noise disappears, you've found the source.
Old Dec 6, 2014 | 10:27 AM
WhiteXKR's Avatar
Once the belt is contaminated with coolant, often the only permanent solution to the chirp is a new belt.
Old Dec 6, 2014 | 04:04 PM
gatekeeper's Avatar
Sorry, don't agree with this. That may make the chirp more profound. Or, make it chirp if that wasn't the noise to begin with. The silicon paste works, if it's a belt noise.
Old Dec 6, 2014 | 06:10 PM
Mikey's Avatar
Any outcome will indicate whether the belt was/wasn't the cause.
Old Dec 9, 2014 | 01:32 PM
CleverName's Avatar
There is also a TSB on this for earlier Jags.
They replace a pulley and belt
Thang Nguyen
Oct 12, 2015 01:25 AM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
reb1999
Sep 19, 2015 07:30 AM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
raulan
Sep 10, 2015 12:43 PM
