Clearcoat lacquer repair.....
Old Mar 17, 2015 | 02:47 PM
Bigfella's Avatar
Default Clearcoat lacquer repair.....
Lacquer repair
Hi, just sounding out some advice on clearcoat lacquer issues.
I have a thumb nail size area which has lifted by the passenger door handle (06 XK). It's just in the reveal next to the trailing edge mounting area so barely visible unless crouching down and really looking for the fault. The lacquer has lifted and allowed dirt / water behind it making it more noticeable.
I was thinking of just slicing the blister off with a craft knife and touching the area in with a brush to cover the base coat and hopefully stop the area getting any larger. Don't even want to try feathering the edges off as I think the clearcoat lacquer is lots tougher than basecoat and I'm wary of sanding through tha basecoat inadvertently.
Wont be anything like invisible however owing to the location it can't really be seen that easily and should prevent further peeling etc........
Any advice much appreciated !
Old Mar 18, 2015 | 01:15 AM
Old Auto's Avatar
Hi , what you intend to do sounds fine.
Make sure you remove any wax etc from the chip with a non abrasive compound then touch in with lacquer allowing each coat to dry properly.
Once you built the level with a few applications and if your feeling brave it is possible to lightly sand the touched in area with a small 1" x 1" sanding block and 1500 wet and dry, then polish back up with compound.
Old Mar 18, 2015 | 02:28 PM
Bigfella's Avatar
Cheers, think I'll give that a try. It's tempting to try feather the edge of the broken lacquer before touching in but I can envisage sanding right through the adjoining unprotected basecoat . Your suggestion sounds good !
Old Mar 18, 2015 | 04:14 PM
Old Auto's Avatar
Under no circumstance try to feather the chipped lacquer...unless you fancy getting the spray gun out.
When touching in the lacquer its a good idea to buy a nice artist brush from a hobby supplier as the lacquer touch in brushes are usually to coarse to apply a nice lacquer touch in.
BoarHawg
Dec 14, 2015 12:21 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
LnrB
Sep 18, 2015 09:48 AM
JimC64
Detailing / Car care
Sep 22, 2007 01:17 PM
JimC64
Sep 19, 2007 08:44 PM
