Convertible top
Old May 11, 2021 | 08:52 AM
Baxter3319's Avatar
Default Convertible top
How many turns should it take to manually lock my convertible top
Old May 13, 2021 | 06:22 AM
Bond's Avatar
Greetings Baxter,
If you have been following my thread from a couple of days ago, I obviously don't know. But I suspect my issue may be related to a problem with the latching mechanism. In any event, I will be watching this to see if any body has a definitive answer. From my experience, the allen bolt on header turns and does nothing. I plan to tear into it today, providing I think it can be done without damaging the brittle plastic components. Good Luck, if I learn anything I will post.
Old May 13, 2021 | 09:43 AM
Cee Jay's Avatar
I don't know about the X150, but the Windscreen Header pawl activation on my X100 took a LOT, like maybe even 30+ full turns to go from Full Unlock to Full Lock. Was not a small amount, and I didn't think it was doing anything to start with.
Old May 13, 2021 | 12:05 PM
Bond's Avatar
Baxter, I just posted pictures of the latching mechanism. With mine no matter how many turns, it would not open or close because one of the cables was bad. To remove the header panel is relatively easy. the manual says 6 screw and 4 clips. There were 8 screws. the clips are internal, carefully pry once screw are out.
Old May 13, 2021 | 01:06 PM
pk4144's Avatar
CeeJay is right - it's a LOT of turns. More than you'd think. Just start cranking it. Don't worry - you can go kinda hard-n-fast with it. And if memory serves (White XKR could confirm this), at some point the cranking will actually get easier as the top has closed all the way and something in the mechanism disengages. But remember you've REALLY gotta pull down on the top pretty hard to get those two latch hook close enough to engage before you start turning.
Old May 14, 2021 | 12:42 AM
Edishp's Avatar
hi, I made a video for you, if you can play it in slow motion than you can count how many turns..
Dennis07
Aug 13, 2020 08:40 PM
Xjeffs
Jul 20, 2020 04:45 AM
Dukejag
Jul 16, 2019 02:07 AM
lonejag
Jun 19, 2018 12:48 PM
