Coolant - Red or Yellow or combo
Old Jun 9, 2023 | 01:21 PM
JDog's Avatar
Default Coolant - Red or Yellow or combo
Ok, I searched everywhere and was looking into coolant. I know read your manual. I recently busted a coolant return hose (plastic) while changing the oil. Some coolant leaked out. I had some Premium Prestone (yellow) and just filled up the reserve tank. Now I find out that this was a no no. I have read do not combine the two different coolants. Any input would be great. And yes I am having the system flushed and replaced with the good orange coolant. What happens if you combine the two?
J
Old Jun 9, 2023 | 05:00 PM
shemp's Avatar
https://carfluidpro.com/can-you-mix-...ge-antifreeze/
I'd get it flushed and replaced asap but this seems to say it's not a huge issue.
Old Jun 9, 2023 | 05:25 PM
bocatrip's Avatar
If were my car, I'd bite the bullet and pickup a gallon of coolant from Jaguar and be done with it. I just replaced all my plastic coolant hoses along with the OEM Jaguar coolant which set me back around $85 for the coolant. Make sure you get all of the old coolant out and if possible do a vacuum fill. It took me a few days of driving to get all the air out of the system.
Old Jun 9, 2023 | 06:06 PM
Sean W's Avatar
J
do you mean Prestone Platinum? Not familiar with Premium Prestone and can't find it in a search. If it's the Platinum you're referring to, the product page says:
  • Universally works with all fluid colors; All OAT, POAT, HOAT & IAT; G05®, G11®, G12®, G12++®, G13®, G30®, G40®, & GG40®. For all engines & engine sizes, new and older engines.
Old Jun 9, 2023 | 08:42 PM
xalty's Avatar
prestone is what ford has to replace orange texaco/havoline xlc
no flush needed
Old Jun 9, 2023 | 08:58 PM
jahummer's Avatar
Too much misinformation here.
Jags and Rovers need Dex-Cool, OAT coolant, typically orange. Mixing OAT with other types might be a problem depending on what it was mixed with. Brand and colour's NOT an accurate indicator of coolant type, read the bottle. Prestone Dex-Cool's always orange, not yellow.
Old Jun 9, 2023 | 09:05 PM
xalty's Avatar
Jags and Rovers need Dex-Cool, HOAT coolant, typically orange. Mixing HOAT with other types might be a problem depending on what it was mixed with. Brand and colour's NOT an accurate indicator of coolant type, read the bottle. Prestone Dex-Cool's always orange, not yellow.
prestone’s current coolant = ford yellow wss m97b57
drop in replacement for dexcool look at the transit tsb.
Old Jun 9, 2023 | 09:19 PM
jahummer's Avatar
Yeah that's not Dex-Cool and NOT engineered for JLR engines....and if you think it's ok because Ford used to own JLR, it's not.
Old Jun 9, 2023 | 09:26 PM
xalty's Avatar
the aj133 was finished in 2006 😂
wss-m97-b44d is literally printed on the expansion tank
Old Jun 10, 2023 | 05:26 AM
RichardS's Avatar
Mixing OAT / longlife of any colour with OAT / longlife of a different colour will never cause a problem.
The internet will tell you that mixing OAT with non-OAT antifreeze can cause a problem but I have never seen the slightest hint of any problem so, in my view, the internet is probably wrong. However, I would always stick with pure OAT if possible, whatever the colour.
Richard
Old Jun 10, 2023 | 07:49 AM
Kongo1's Avatar
This has got to be one of the most frustrating subjects that I have come across. Some information states dec cool and others state the pink g30 for modern Jaguar engines.
Old Jun 10, 2023 | 09:33 AM
JDog's Avatar
Default Preston Platinum Pic
After reading all the replies, I just went ahead and drained and replaced with Dex-Cool orange. My mechanic was replacing the coolant return hose so I just had him drain and replace the coolant too. Here is the pic of the Prestone that I used to top off the reserve tank. I drove home yesterday in 95 degree heat here in Houston. I can't afford to loose my car engine by mixing the coolant.
Thanks to everyone for all your replies.
Joe
Old Jun 11, 2023 | 08:47 PM
sailor's Avatar
J
As I understand the coolant situation and I may be wrong but. here goes. The older yellow/green type coolant was basically what we used for years on the older steel engines. When aluminum engines started being used, Ford discovered they were having to replace engines under warranty because the coolant was destroying the aluminum head gaskets. Ford replaced my engine on a Taurus twice. The newer pink/orange/red type coolant is a special low silicate antifreeze and is specified by nearly everybody using aluminum engines and cyl heads.
It is known as long life coolant and usually (always?) comes premixed with spcial ion free water.
Old Jun 12, 2023 | 02:01 AM
RichardS's Avatar
Antifreeze colours have varied widely over the years clear / yellow / blue / green / red / pink / orange and all flavours have been available in all the colours over the years so the colour really doesn't mean anything at all.
OAT / Long Life / Silicate-free antifreeze was introduced in the 1990's. Aluminium had been used in engines for decades before that and some of the pre-OAT antifreezes were developed specifically to be increasingly effective with aluminium although OAT was even better in this regard. Ford may have had a problem with their engines but it would not have been specifically related to IAT antifreeze although that might not have helped matters if that is what they were using.
The current OAT / Long Life / silicate free antifreezes are still available in many colours and I have personally used pink, clear and blue versions. I always buy the undiluted versions and dilute them 50:50 with distilled water.
Richard
Old Sep 15, 2023 | 05:35 AM
2018XF25T's Avatar
I use DEXCOOL on my 2018 XF
Old Sep 15, 2023 | 10:08 AM
RichardS's Avatar
Dex-Cool is a typical red/pink OAT long-life antifreeze branded by Vauxhall/Opel/General Motors. It will usually be more expensive than an identical antifreeze which is not branded by one of the big car manufacturers.
Richard
glenmo25
Jan 5, 2023 03:05 PM
alistairolsen
Dec 7, 2020 07:01 AM
Ordhyait
Mar 29, 2019 10:39 PM
davealberta
Oct 3, 2014 06:20 PM
newjagowner
Oct 5, 2012 04:44 PM
