First strange noise.
Old Jul 10, 2017 | 04:08 PM
chazaroo's Avatar
Default First strange noise.
I noticed it yesterday and today. When accelerating from a stop a whistling kind of sound for two or three seconds. Almost sounds like a bearing. Today I noticed that it only does it when the AC is running. The noise is similar to brake pad squeal but higher pitched. Does this sound familiar to anybody?
Old Jul 11, 2017 | 06:09 AM
steve_k_xk's Avatar
Yes Yes I have this exact same sound on my e550 ...will teach me to fit up a Chinese branded AC pump
Id say the bearing on the AC unit are on their way out
Old Jul 11, 2017 | 07:21 AM
chazaroo's Avatar
But your AC works OK?
Old Jul 11, 2017 | 12:07 PM
steve_k_xk's Avatar
Air con still works fine but yes I get the noise when it's switched on
Old Jul 11, 2017 | 04:46 PM
pk4144's Avatar
You have a 2007, yes? This may not apply to you, but two strange questions:
- does the noise sound like it's coming from behind the instrument cluster, sort of? Sounds like it's coming from a specific location in front of you?
- does it get stronger when you accelerate, or rev the engine? Especially accelerating between like 1500 and 2500 rpm?
And this "whine" is a single, very-high-pitched noise that kind of fades in and out, and ONLY occurs when the A/C is on? I had a noise like that which is a known problem, it's an A/C-related issue that is fixable at a dealer, costs about $200, and there are threads on it elsewhere here.
It drove me crazy, and the fix worked perfectly. But... I think it only occurred on 2010 and after model years. Not sure.
Old Jul 13, 2017 | 08:53 AM
chazaroo's Avatar
Mine is a 2010 and I think you are right. i just found a mention of a AC whistle type sound and a Jaguar bulletin on it: JTB00207. It's apparently not anything to worry about, just annoying. I'll get it taken care of next time I'm in for service.
Old Jul 13, 2017 | 09:57 AM
pk4144's Avatar
Yep. Interesting story that I relayed elsewhere:
It's one of the few things may warranty would not pay on. Why? Because even though the TSB implies a defect in the original design... the fix, which requires the addition of an O-ring and spacer, involves parts not original to the car. Even though they're Jaguar parts, and the o-ring and spacer setup is built into newer cars. Oh well. (The problem, as I understand it, is there's a hard, right-angle bend that it's hard for the coolant to go around, and the fix addresses that. Something like that. Anyway, it works.)
