View Poll Results: What kind of leak is this??
Hydraulic Leak
0%
Gasoline Leak
0%
Water Leak
100.00%
From Some Other Source of Leak
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Found leak in backseat behind Driver's Need Suggestions
Old Aug 6, 2023 | 02:46 PM
McJag222's Avatar
Is it possible to use a shop vac to try and suck what's left in there out. There may be a grommet or something to remove to poke in some small diameter plastic pipe attached to the shop vac hose.
Old Aug 6, 2023 | 02:53 PM
dstrong11's Avatar
I'm going to take it to the local Brand New Tidal Wave and use their vacuums to suck up the access liquid and I'll use their super duper strong air blaster to clean out that rubber seal! That should fix it let's hope it will...
Its brand new and their air is amazing
Old Aug 6, 2023 | 03:35 PM
kj07xk's Avatar
Sounds like it’s time to get underneath and see what is below that hole. Look for dampness in the area to see if something else is throwing liquid towards that spot (brake line, transmission, differential, fuel pump, whatever). There’s also a small pump up behind the left rear wheel well that provides vacuum to run the exhaust valves, but don’t think that could have produced that much liquid if it leaked. Weird.
Old Aug 6, 2023 | 04:24 PM
McJag222's Avatar
I wonder if the drivers side window was left cracked open (done that myself) and rain got in there and wasn't completely removed in half **** dry/cleanup job?
Old Aug 6, 2023 | 04:58 PM
dstrong11's Avatar
Could have been... well it won't be getting anymore liquids inside except maybe bottled water lol 😂
Will keel the replacement seat and cushion off for this entire to week to see if any liquid water or otherwise comes upbfrom this spot.
Now its all dry
Cleaned up the spots of liquid... all dry at the moment
Old Aug 6, 2023 | 05:50 PM
McJag222's Avatar
Looking good, you might have some more if you drive up hill and it sloshes around. Hopefully you got it all. Good thing is that is not ferrous metal.
Old Aug 7, 2023 | 09:41 AM
Bill400's Avatar
The solid grommet in your photo is above the fuel tank.
The source of your latest "leak" is likely residual weeping from the seat back.
My guess is (1) hatch gasket near the top or (2) residual "flood" water.
Examine under the seats. A flood will usually cause rapid corrosion on unprotected steel, seat rails and structure.
Please keep us posted.
Old Aug 7, 2023 | 11:01 AM
  #28
Cee Jay's Avatar
Could the sticky ooze be saturated and congealing leather? It gets sticky and oozy when wet and it breaks down.
Old Aug 7, 2023 | 11:16 AM
dstrong11's Avatar
It may have, and that's what caused it to be sticky since it was sitting in cushion pad which has spray glue on it from the factory including parts of the seat cushion itself...
it ruined both the seat armrest and the seat pad of foam underneath it...
The pad underneath the seat is trash... so me and my Mom came up with an ideal replacement lol see attachment photos 📸.
The ooze lol
This will not be going back in the car...
The seat is junk... the Leather is cardboard hard! Luckily I have perfect replacement 👌
Mom traced the outline of the crap seat sponge thats coated in the ooze and cut it from the rug mat...
This carpet mat we found at Dollar Tree 🌳 for $1.25 and its a perfect replacement for the destroyed rear seat mat!!
Old Aug 7, 2023 | 12:01 PM
  #30
CurtJ's Avatar
Could it be seepage from the foam? I can't think of anything that would be leaking back there in a coupe.
Old Aug 7, 2023 | 12:13 PM
  #31
dstrong11's Avatar
It could be since it's the only thing that was doing it from the car... That middle pad and rear seat bottom. I hope no one else has this problem with their Coupes...
It's crap to deal with but it must be dealt with...
Old Aug 7, 2023 | 01:38 PM
  #32
CurtJ's Avatar
I wonder if you could use a small rolling pin or something similar and tried to press the fluid out of the foam. I don't know what the foam is, but water might be slowly dissolving it and making the seepage look more like hydraulic fluid...
Old Aug 7, 2023 | 02:33 PM
  #33
dstrong11's Avatar
I pressed the foam and squeezed as much goo out with a hammer 🔨 and a paper towel to get what I could out of it, and put the pieces of crap to bake out in the sun 🌞 hoping to at least get the liquid out... it's so greasy you guys...
Greased up towels...
This stuff smells like old glue lol
Old Aug 7, 2023 | 02:47 PM
  #34
jahummer's Avatar
FYI, the original leather in your car's premium leather and the replacement part you purchased is Ambla vinyl, not leather.
Originally Posted by dstrong11
Whatever the hell it was it ruined this seat cushion and disformed the leather on the armrest
Look at the difference in the two... one i just bought off a 2014 XK the other is totally ruined...
Old Aug 7, 2023 | 02:54 PM
  #35
dstrong11's Avatar
It's ok though for now, because I'm not putting that greased up junk back in the car lol
Old Aug 8, 2023 | 05:22 AM
  #36
Stuart S's Avatar
I had to enlarge the photo on my phone to see the difference. jahummer is right.
Genuine leather is smooth, without any texture. (Not shown - only the center sections of the front seats are perforated).
Vinyl is not smooth, and has a pebble grain finish.
Old Aug 9, 2023 | 04:03 AM
  #37
Pipes's Avatar
I found water under both rear seats, I dried it out properly and it never returned.
I tried running a hose over the car with the speaker panels and seats stripped out but I couldn’t find any leaks.
Old Aug 9, 2023 | 03:58 PM
  #38
dstrong11's Avatar
Once I got all and any liquid still left out I finally got to put it the new pad and lower seat and armrest.
It turned out pretty good if you ask me considering these are replacment parts from a 2014 XK...
The $1.25 carpet mat from Dollar Tree 🌳 to the old foam mat that smells like old grease lol...
Carpet side up
The new replacement seat from the 2014 XK
The replacement compared to the old jacked up seat...
Snuggled in...
Put the replacement armrest back in...
Looks better for sure!
This will do for now 😉! Looks better than before...
Old Aug 9, 2023 | 06:10 PM
  #39
McJag222's Avatar
Looking good.
Old Mar 26, 2024 | 04:01 PM
  #40
trkyam's Avatar
I had a gas leak coming from that exact flange,
this is very suspicious that perhaps someone tried to clean up a gas leak from the fuel tank access port.
Check under the rubber grommet and verify your flange isn't leaking. my car is the same year as yours.
