Front and Rear dics size
My car been a 2007 xkr, can anyone tell me the size of my Rear and Front brake discs. The rears are of drilled holes and slots design and need replacing as i am doing the pads as well. Fronts discs are flat, but want to replace them with those of the rear design.
Found these on the MTEC BRAKES site, what you think,
Brake Discs and Pads for XKR 4.2 Supercharged 06/06-06/09
there is 2 front and 2 rear sizes, but i don't know which is my size as i would have to have them out to get the size.
Then there's the pads do i go for Mintex, then there's , Red, Yellow and Green stuff, what's the difference.
Does this video explain it as it is or anyone disagree,
Any recommendations most appreciated.
The information below is from my workshop manual. I don't think your Jag had drilled and slotted discs on it from the factory. Mine didn't and I haven't seen one that had them unless I already knew they had been changed out.
Specifications
Brake Disc
Item Specification
Disc type Ventilated
Disc diameter (Supercharged models) 355 mm (13.98 in)
Disc diameter (vehicles fitted with Alcon braking system) 400 mm (15.75 in)
Disc thickness (Supercharged models new) 32 (1.26 in)
Disc thickness (vehicles fitted with Alcon braking system new) 36 mm (1.42 in)
Minimum disc thickness (Supercharged models service limit) 30mm (1.18 in)
Minimum disc thickness (vehicles fitted with Alcon braking system
service limit)34 mm (1.34 in)
Disc thickness variation (new) 0.008 mm (0.0003 in)
Maximum disc run-out - installed 0.09 mm (0.0035 in)
Maximum hub face run-out - installed
0.0135 mm (0.00053 in)
Specifications
Brake Disc
Item Specification
Specifications
Brake Disc
Item Specification
Specifications
Brake Disc
Item Specification
Sorry Powerhouse, I misread your request. Here are the specs for the rear.
Specifications
Brake Disc, Rear
Item Specification
Disc diameter 326 mm (12.8 in)
Disc diameter (vehicles fitted with Alcon braking system) 350 mm (13.78 in)
Disc thickness (new) 20 mm (0.78 in)
Disc thickness (vehicles fitted with Alcon braking system new) 28 mm (1.10 in)
Minimum disc thickness (service limit) 18 mm (0.70 in)
Minimum disc thickness (vehicles fitted with Alcon braking system service limit) 26 mm (1.02 in)
Maximum disc run-out - installed 0.075 mm (0.0029 in)
Maximum hub face run-out - installed 0.0135 mm (0.00053 in)
Specifications
Brake Disc, Rear
Item Specification
