front tag busted
Old Sep 30, 2014 | 08:05 PM
RedRider48's Avatar
Default front tag busted
Hey Guys,
Got nailed this past weekend for not having my front tag mounted while on the way to a Concours d' Elegance.I received a $70 *****. Crazy thing, the trooper noted, I didn't have a rear tag either. NOT TRUE! I'm going to make a court appearance as I've only had the car tagged since earlier this month (09-Sept) am going to state my case as not having time to order a front mount assy. Also the trooper errored in mentioning on my ticket, I didn't have a rear tag displayed......Go Figure?
Now, I have to figure out how to "elegantly" mount my front tag.......?
Old Sep 30, 2014 | 08:25 PM
Ceckman's Avatar
In California that is considered a "fix it ticket". Meaning that you have the option to make the noted correction or pay a fine. I never put front plates on my cars and have been cited only once that I can recall. Another "fix it" infraction is tinted windows (that I have been cited on more than once). In either case - I pay the fine (most recent was a window tinting ticket that cost me $195).
Not sure it is the same where you are.
I would note that (from purely my POV) the aspect of the trooper making an error on the ticket regarding your rear tags.... Meaningless. Don't hang any hope on that getting you consideration from a Judge.
Old Sep 30, 2014 | 08:32 PM
mosesbotbol's Avatar
Only time in 12 years of no front plate on my car was when I was parked at meter in front of town hall.
Old Sep 30, 2014 | 08:43 PM
RedRider48's Avatar
Hi,
Thanks for your comments. Naw, I'm not "hanging my hat" on the trooper mentioning I had no rear plate too, to get any pity. But will, go with the story, the car came from a state that didn't require a front tag and I had to order an entire assy........???? (PS: I really did)
Old Oct 1, 2014 | 05:42 PM
DaveC's Avatar
You'll last about 15 minutes in San Francisco without a front plate if you are parked. My daugher even got spotted when she was nose in parked in an underground garage! otherewise, the rest of the state is fine. It's just like fish in a lake. Someone is going to get caught eventually.
Old Oct 1, 2014 | 06:07 PM
jaguny's Avatar
There is an Ftype thread on this topic. I posted there. That I have seen an automated license plate retraction device that conceals the plate under the front lip and extends it out and up via motorized connection. Saw on a forum few years back. You can try googling. This may be the elegant solution.
Old Oct 1, 2014 | 06:19 PM
DGL's Avatar
DGL
On the GT-R forum most owners use the tow hook access hole. A back plate can be ordered to screw in the hole to mount the plate on. Good luck with the ticket.
Old Oct 1, 2014 | 07:04 PM
RobB's Avatar
Now if we can get this linked to my laser detector, and get it to retract really quickly, we're on to something!
Old Oct 1, 2014 | 07:06 PM
liquid-chris's Avatar
I just received my "Altech Show n Go" Home - Altec Products Inc.
Remote control retractable. Ebay $109. I'll post a pic when I get it installed in a week or two.
Old Oct 2, 2014 | 08:59 AM
jagtoes's Avatar
Lightbulb
New york has some pretty tough front plate laws .Front plates are required for tag identification and the easy pass system. Also you can't have anything covering or blocking any part of the plate. You have to pay the fine and show proof you fixed it. Easy pass uses a camera and transmitter for tolls and cops use plate as laser target.
Old Oct 2, 2014 | 09:55 PM
ralphwg's Avatar
I have my laser detector built into the front license plate frame. therefore I keep the license plate on the front all the time.
Old Oct 3, 2014 | 05:10 PM
RedRider48's Avatar
Yeah, I've been given that "tow hook" location some thought too.
Thanks for your comment.
Old Oct 3, 2014 | 05:19 PM
amcdonal86's Avatar
I used a cheap license plate holder, dishwasher hose to keep the license plate holder away from the bumper, and threaded some toggle bolts through the dishwasher tube. This way I can theoretically remove the front plate holder when it comes time to sell without any marks. It is also perfectly centered, unlike if you used the tow hook!
Old Oct 4, 2014 | 09:57 AM
RedRider48's Avatar
I like this idea. Will be lurking awaiting your reply......
Old Oct 4, 2014 | 10:42 AM
Muddydog's Avatar
RedRider, here's an old thread you may find interesting. There are lots of ideas buried in it. Maybe you've already seen it, but thought I'd link it just in case. https://www.jaguarforums.com/forum/x...e-plate-59021/
Old Oct 4, 2014 | 11:46 AM
RedRider48's Avatar
Hi,
Yeah, I've read through many of these and did find many of the ideas helpful.
Thanks for a reminder....
I find the remote retractable plate bracket interesting. I'm going to wait for his reply.
Old Oct 4, 2014 | 12:01 PM
jagtoes's Avatar
Although I think the front end looks great without a front plate there was no way I could get away with it in NY without local harassment. When I got the car from Maine I mad sure they shipped an OEM front plate holder with it but not attached. Looking at the stock mount I wanted to have the top of the bracket flush with the top of the center bar. In order to do this you need to mount the bracket upside down and you will see the bracket contours fit against the center section. So under the center I mounted a 1" aluminum angle with 2 self tapping #8 SS screws. I put double sided foam tape on the back of the bracket and pressed it on the front center section. Where it stuck below the center section (it fully covered the aluminum) I drilled 2 holes and secured the plate holder to the aluminum. I then mounted the licence plate using anti-theft SS screws. Looks good and legal and if I ever remove it there are no holes in the front of the bumper center section.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
johndahlheimer
Sep 16, 2015 05:44 PM
drewlabarbera
Sep 14, 2015 07:46 PM
jaaag
Sep 11, 2015 12:53 AM
