Headlight Seal
Old Mar 2, 2025 | 03:39 PM
indyx358's Avatar
Default Headlight Seal
Does anyone have instructions on how to take apart a headlight unit to reseal it? I’ve heard of the oven method but I cant find a video anywhere on the internet. I don’t want to experiment and use my “best judgment”. I need step by step instructions. Help?
Old Mar 2, 2025 | 05:38 PM
wymjym's Avatar
Read the posting titled LED Halo Headlight in this forum from last week. There are instructions
WJ
Old Mar 3, 2025 | 07:19 AM
guy's Avatar
guy
And the thread "green junk".
Old Mar 13, 2025 | 05:09 AM
steve_k_xk's Avatar
It's been done a few times by members , make sure you bake and low temp continuous checking the rubber components (being low heat you should be fine ) there also is a hidden torq screw make sure that is removed.
In terms of resealing simply do the reverse in order to heat up the glue/sealer then reseal the lenses .
Ive never had a problem using this method although I did run into issues the first time when I didn't reheat the sealer and used an off the shelf product
04Xjrsteve
Oct 4, 2024 02:10 PM
malc4d
Jan 22, 2024 08:32 AM
placer61
Nov 1, 2023 03:04 AM
Kiddent
E type ( XK-E )
Jun 8, 2021 07:13 AM
